coil overs r230
JBell
Torquey
C350 CDi Estate (GAD Edition)
Sounds good AJ, the current model indeed quotes as having ‘multi link w/coils’ so a very much more traditional approach
I wouldn't hesitate putting a good coilover set up on an SL 55, would love a project like that, money and time allowing
ajlsl600
ajlsl600
france
  • #42
I found some KW variant 3 coilovers for the r230 (V8). They have adjustable compression and rebound and ate $2800 a set. You'd still need to add sway bars and a pump and some way to fool ABC to that. Being coilovers they should be easy to fit different springs (stiffer) if needed. Not sure how much stiffer or how much additional damping the V12 would need?
for v8 sway bars exist. and the pump that does the job is off an ml and apparently with star you can tell the system its NOT abc and no longer see warnings ect there is plenty on this on the ...other.. forum...
Ah interesting....
I also just found this:
http://www.kwsuspensions.com/dlc
Its an neat little (very expensive) unit to allow lowering a car with ABC by using an ECU to fool the system into setting the height to whatever you want (upto 30mm lower). Works on SL/CL/S class by the look of it.
Still doesn't get rid of ABC mind!
ajlsl600
ajlsl600
france
  • #44
looks neat, however another electronic gadget to mess with my head 5 min out of its warranty is a no no for me.
ajlsl600
ajlsl600
france
  • #45
well guys so far no response from vvk. which was the coil over kit as on utube sl55 so either on hol or out of bussiness. thee are others but only this one listed r230sl600. unless someone out there knows better.?
ajlsl600
ajlsl600
france
  • #46
money was not bad under 4k usd, but cant seem to get a reply from vvk usa
ajlsl600
ajlsl600
france
  • #48
only fits non abc i think
ajlsl600
ajlsl600
france
  • #50
no sweat john , still looking there is a demand for the 55 and 600 in the states just have to see subject on the ....other... site , not so much in the uk, possibly germany.will check , did you see utube on guy doing 55 in states i think i put link on here ,but can find it again.it looked a good job , small bother with front sway bar. at under4k usd then. not so bad
Naraic
2005 CL500.
$4k...ouch.
Yellowspeed do the complete adjustable kit for the W215 for about £850. Roll bars from a W220 are peanuts as is the steering pump. ABC warnings can be coded out by STAR.
ajlsl600
ajlsl600
france
  • #52
had reply from vvk in usa, they say they are making the kits 500,55,600 r230 again tried pasting his mail,cant ,will just pass his conact i have asked for customer info on the kit fitting and after fitting performance will find a way to add that here .LK how come i cant copy .paste email repies here ?
ajlsl600
ajlsl600
france
  • #53
vvk.usa.contact@gmail.com sean . best i can do right now . but there has been delivery delays as most items outsourced. quality however has as seen by me online very good and confirmed by the guy who fitted to 55 in states .utube. sl 55 coil over. check the other site as well.
Should be able to paste it. It's just text.
ajlsl600
ajlsl600
france
  • #55
ajlsl600
ajlsl600
france
  • #56
  • langley Andy hi . i am trying to contact you ref coil over kits for 50 55 and 600 sl r230 mb can you provide anyinformation on these kits, and reference a user or two. rgds ajl
    15 Oct at 6:52 PM
    VVK Hi Andy, Sean here, co-founder of VVK, I'm sorry for not answering faster, we had an employee leave suddenly and I've been quite sick, so just trying todo my best while I look for new hires. As of next week we will have both a certified Mercedes and BMW tech working in-house and staffing emails also. We have done a dozen or so of these kits, and they are each hand-assembled here in Florida, specifically for each customers needs. Spring rates and damper valving varies for the V8 and V12 cars as well as the S
    Today at 4:46
    To
    VVK
    Today at 7:51
    sean , yup i have an interest for my own v12. yes i would like to contact someone running yr fitment ad yes there are others interested on our uk mb forum
    On Friday, 20 October 2017, 4:46, VVK <vvk.usa.contact@gmail.com> wrote:
    561-542-28
ajlsl600
ajlsl600
france
  • #57
think that seems to cover current situation. LK no idea wot happened1st attempt
www.W140.co.uk&www.r129.co
