Connecting phone to Bluetooth W219
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Rhys07, Jun 14, 2018.
  1. Rhys07
    Rhys07 Active Member
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
    My 2008 CLS 320 came with Bluetooth cradle: A2048200535. I've gone through the connection process - it picks up my phone, I put in the long code from the screen in to my phone and it connects. But then the screen in the car says "activate phone", and the small screen behind the driving wheel says "trn on phone". I've heard that some phones need you to change a setting to allow it to connect, but I can't find anything on mine. Can someone help? I'm using a Oneplus 3. Thanks
  2. OP
    Rhys07
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
  3. AMGeed
    AMGeed Senior Member
    4,871
    1,087
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG
    I assume you have paired your phone to the bluetooth puck? Bluetooth on the phone turned on etc?
    It sounds from your description that the car hasn't recognised your phone yet.
    Can you borrow a phone, insert your sim card and see if it recognises or pairs with that one?
  4. Botus
    Botus Senior Member
    2,671
    422
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    that's an SAP adaptor
    its a bit different to all the others..... it works by "stealing" the mobile phone's SIM card data using the SAP Bluetooth profile
    if you had an old mobile the world is all normal.... using a windows or apple phone this unit can't work... there are some apps you can install on android that will allow the unit to get at the SIM via SAP
    either do some research and add an app or buy a different unit
    AMGeed likes this.
  5. OP
    Rhys07
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
    That was very helpful. Thanks. Just read up about it and how it works now that I know what it is. The main reason that I wanted to make this work was to play music over Bluetooth, but it seems that that's not possible with rSAP. Unfortunate.
  6. Botus
    Botus Senior Member
    2,671
    422
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    you won't get any BT music streaming as std on an old Merc... it came in around 2011
    the UHI socket is ONLY mono
    there are ways...
    FM re broadcast nasty with interference, but very cheap
    via axu in and a BT module no visibility in car or navigation of tracks, but can be very cheap
    via the clunky merc ipod interface and a viseeo or similar tune2air pricey
    via fiscon or dension aftermarket kit.... silly money 450 to 800, but ends up as if original fit, on the dension kit dependant on the car, can get DAB in the mix as well
    Rhys07 likes this.
  7. Botus
    Botus Senior Member
    2,671
    422
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    these units are a bit of a nightmare to understand which you have.... looks very similar to my fathers E280 and without 3D maps the display is awful with zoom being hard work.
    [​IMG]
    Rhys07 likes this.
  8. John Laidlaw
    John Laidlaw Senior Member
    17,637
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Fitting a new head unit seems to be the best option on the older models if you want full functionality, quite a few on here have done it....
    GLK and Rhys07 like this.
  9. OP
    Rhys07
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
    I have thought about it and it's very tempting, but I'm reluctant to get rid of anything original! Do you know if there's a suitable head unit out there that looks similar to the original?
  10. John Laidlaw
    17,637
    4,312
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Rhys07 and GLK like this.
  11. GLK
    GLK Senior Member
    3,089
    1,043
    Sep 19, 2014
    Northampton
    Your Mercedes:
    A200 Avantgarde Special Edition Sports Coupé • C169
    Thanks John :)
    Rhys07 - if you're considering an aftermarket unit, there are two main options - brand name (and high quality) like Alpine or Pioneer, but it will have to be mounted into some kind of frame / adapter / fascia; or a model-specific unit from one of Chinese manufacturers, like Xtrons (as above) or Erisin.
    I seriously dislike those frames to accommodate a standard Double-DIN in place of OE unit, so I went for a model-specific unit for my car.
    Out of this type, you have another two main choices: units that mimic the OEM look - namely COMAND - or a more modern type, with larger screen and no DVD drive. I went for the latter, as my interior doesn't look OEM anyway ;)
    [​IMG]
    Fitted it myself last August and it's been perfect so far. Everything works, including steering wheel controls; reversing camera (and left mirror camera), dynamic parking guide; satnav; OBD-II diagnostic via Torque Pro, etc etc. Sound quality is really good, and I do have a factory Power Sound option, with extra speakers and a subwoofer. The installation was a simple plug-and-play.
    I didn't keep the old head unit, nor the CDC or the telephone console, but as John said, you can always retain them to put back, if desired.
  12. OP
    Rhys07
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
  13. OP
    Rhys07
    39
    5
    Jun 11, 2018
    South Wales
    Your Mercedes:
    CLS 320 W219
    Wow that's impressive. I've just had a browse at units that mimic the OEM. Really good option for me. Thanks!
    GLK likes this.
Share This Page
