Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
Discovered a small hole in one dust cover. MB do sell them #A0014210986 (£12 for others who have C216s), but they do not sell a piston seal kit.
Hence I need to ensure water does not corrode the piston or its a whole new calliper! £224
Bought them
Picture from the calliper side
Re Question is one Brembo refurbisher says you can fit them in situ without removing the calliper.
Do you think this is possible?
He said just squeeze them in at the edge, and then when you push the piston back they just go in :-0
Do you reckon he is right?
You only have real access from the back i.e. This side.
From the front there is a bar that gets in the way
This is the access with the pad removed
You can just about get ones finger 2/3 to the back, plus no idea how hard one has to push to get it in, or does it possibly go over a protruding lip?
Anyone done one of these?
Close up
And it would Be exceeding difficult to get to the back edge of the dust cover to push it into a groove or over a lip, as that bar stops access from the other side.
Side view of the new one
As it would sit againt the calliper wall
I had hoped to drive the car to an Indy, to fit new pads, yes I know its simple but would rather have the peace of mind its done right.
The issue is if I pull off the split dust cover, will I be able to get the new one pressed in (or over any lip that may be there)?.
Plus one is kinda limited to see how well one has cleaned up the rear of the dust cover groove without taking off the calliper.
This dust cover feels like its got a metal backing inside the side that goes into? The calliper groove, or does it go over a lip, or maybe just sits up against the calliper side Wall (I doubt the latter, re water ingress ).
It would save a whole load of driving if I could do it. And then get the Indy to fit the pads and confirm its all done properly.
My worry is , I get it off, or partly off, and due to lack of access cant get the new one on :-/
Then I would have to take the whole calliper off ... a tad above my comfort zone!
If I got stuck do you reckon I could you drive 70 miles to the indy with the dust cover just "placed" over the calliper?
Any opinions much appreciated, as the pad is out and the wheel off ... all outside crap.
Note my caution is MB do not sell the actual Piston seal, they say that is a new calliper. Hence my desire to ensure the piston is preserved at all costs.
The damage is new ... i.e. One week, effing wheel refurbisher stuck a screw driver into the calliper (trying to push the brake pad against the rotor, to stop the wheel rotating, rather than lowering the car a little! ) at the time I wondered what he was doing
Until he called a mate who opened the door and pressed the brake pedal! Course ai cant prove he did the damage! And All the others are fine!
Bought them
Close up
