Cut and Buff Step by step Instruction
Discussion in 'Autocare, Detailing, Valet, Product reviews' started by brian bray, May 27, 2018.
  1. brian bray
    brian bray Active Member
    28
    3
    May 20, 2018
    Your Mercedes:
    1991 300 sl
    I need some cut and buff guidance. I have a '91 300 SL that was a quality repaint in a red single stage (original color) some years ago but was never buffed out. There is enough paint thickness for a cut and buff.
    I started on the hood with considerable improvement but have not been able to eliminate all of the sanding scratches from my efforts.
    I have done everything by hand as follows:
    1) I keep the surface wet and use a rubber sanding block;
    2) I begin with 1000 grit paper;
    3) then to 2000 grit paper;
    4) then to 2500 grit paper;
    5) then to rubbing compound;
    6) then to polishing compound.
    When I finish all of the above, the surface is absolutely smooth as glass eliminating all the discoloring BUT there are some sanding scratches remaining that keep the look short of perfect.
    Suggestions either for product, technique, equipment, etc.? I can tell that a much better result is within reach but I need some guidance to help me get there.
    Thanks in advance.
    Brian Bray
  2. Binnedit
    Binnedit Senior Member
    141
    79
    Jul 5, 2010
    Smoke on Trent
    Your Mercedes:
    Current: W209 CLK320 A'garde 2003, W211 E280 A'garde 2006 Past: W208 CLK 320, Yr 2000
    Hi Brian
    You've done all that by hand? Crikey, thats a lot of arm work.
    Have you tried using a machine polisher? I suspect it'll get the majority of the sanding marks out with the right pad, compound & polish combo. And much less arm work.
  3. Craiglxviii
    Craiglxviii Senior Member
    13,341
    2,910
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
    Spend £40-50 and buy aDA polisher. Makes it SO much easier.
    You must have an arm like Popeye now, hope you swapped hands or...
  4. OP
    brian bray
    28
    3
    May 20, 2018
    Your Mercedes:
    1991 300 sl
    Binnedit,
    Thanks for your reply and concern. Fortunately, I have only done the hood so far. I am not a masochist so I stopped and got online searching for shortcuts and/or technique suggestions. There are some excellent how-to videos. I also got an offer from a neighbor to borrow his buffer which I'll accept. Things are looking up.
    Brian Bray
    Binnedit likes this.
  5. Binnedit
    141
    79
    Jul 5, 2010
    Smoke on Trent
    Your Mercedes:
    Just be careful if its a powerful rotary (only) polisher. You can burn through very quickly if you dont keep it moving.
    If its a dual action polisher, it should be much safer.
  6. OP
    brian bray
    28
    3
    May 20, 2018
    Your Mercedes:
    1991 300 sl
    Thanks for the warning; I'll be sure to heed. Because I live in Tucson, AZ (over 100 degrees today) I won't be working on the car.
Share This Page
