Have you got the software that shows you Google maps as you go so you can see all sorts statistics and auto joins all the files on the fly so it looks like 1 continuous journey?
But not on a Mac though there is Mac sw out there...it's on the Dashcam forum
Many thanks. Is it a PM?I have printed off the circuit diagram of the camera for you
remove the A pillar covers by prising off the air bag warnings covers, there is a 10mm nut, take this off and the covers pull inwards from the top and you lift them out. You can now feed wires up from the removable side panels from the end of the dash, so adding all time live and switched cables is no problem, going along the top the will push up under the front of the headlining out of sight
Hi Television. Do you know if that's the same sort of set up on an E Class W211 57 plate?
I've been using one of these as a crash-cam for the last couple of months and although it's inexpensive it ain't cheap n nasty.
I'm looking to permanently wire one in to the front and to the rear of my new car.
Perhaps wiring one in to the courtesy lights at the front and somewhere (?) at the back. Top of the rear screen preferably.
The suction mount the GW1 came with is quite small but I'd like to see if I could do away with it altogether, lose the white circle you can see from the outside.
