Before I start - a huge thank you to Martin (M80) for the most elegant solution to this problem, and his remarkable generosity!
Now the matter at hands - most of my secondary consumers, i.e. front and rear dashcams; GPS tracker; HUD; hard-wired standalone SatNav, are powered by a fuse tap to the front power socket.
All wiring is hidden, separate gadgets are fused, etc, etc - so all good there
However, with the recent update on STAR, and removal of the "UK Mode", by Mark at Comand Online, I have a couple of "new" features, namely headlight delay (I had 'follow me home" before); interior lighting delay and pre-start (the correct official name escapes me at the moment), etc.
Being a greedy old git, I enabled them all, and love it ... however, my gadgets - not so much
Essentially what happens is, everything gets powered up, once the car is unlocked, and then goes off, once the door is open. The time is often not sufficient, for the gadgets to complete the power-up routine (particularly the GPS tracker and the front dashcam - a very old BlackVue), so when it's time to start proper, they both take forever to get a GPS fix. A few times these didn't start at all, till the next ignition on point.
Not being terribly familiar with relays and delayed power solutions, I asked Martin for advice, as I know he's an expert. I was thinking, I need to delay the ON signal from the power socket fuse, so I can get into the car, start it, and then the gadgets get the juice after, say 15-20 seconds.
Not only Martin came up with a much better solution (OFF signal delay), but he actually sent me an already configured relay - all I had to do, is fix the wires and stick it into a box:
Absolutely brilliant, thank you so much!
This goes into the car in a few days!
