Decals removed but outline still visible.
Discussion in 'Autocare, Detailing, Valet, Product reviews' started by flowrider99, May 31, 2018.
  1. flowrider99
    flowrider99 Senior Member
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    SL500 (R230) / Audi S5
    I have removed the V6T decals from the wings on my S5 but on one side the car has had some paintwork repair and you can see that the decals were not removed before the wing was painted. It looks like it may be just clearcoat overspray, what can I do to smooth out the clearcoat and remove the V6T outline?
  2. Naraic
    Naraic Moderator
    9,926
    662
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
  3. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    I'm thinking it will need a bit more than T-cut, possibly a light sanding and then a polish.
  4. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    This is not looking good....I have taken to car to a couple of body shops, both think the wing needs a complete respray with one quote at £300! Still waiting for the other quote.
  5. Headhurts
    Headhurts Senior Member
    816
    191
    Jul 24, 2014
    Norwich, Norfolk
    Your Mercedes:
    E350 Night Edition Estate/2016/Diesel
    Not good then, cheaper to put the decals back on I guess unless they annoy you that much.
    Robin
    flowrider99 and Naraic like this.
  6. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    You would think something can be done without a respray. Its only clearcoat sprayed on top of clearcoat to blend the new paint in.
  7. EmilysDad
    EmilysDad Senior Member
    6,645
    858
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I wonder what those body shops would have suggested if you'd driven in with an 'also ran' Astra/Focus/etc :confused:
  8. Xtractorfan
    Xtractorfan Senior Member
    6,077
    143
    Nov 16, 2007
    Your Mercedes:
    S class
    You will have to repaint as decals tend to have a fine line of dirt,black, around the outline, not visible when the decal is in place,
    once it has been taped or lacquered over, this line will now be underneath the lacquer... and very hard to remove.
    A picture may give a better idea of how bad it is.
  9. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    I will try tomorrow to get a photo, its tricky as the reflection of the paintwork is almost mirror like.
    Xtractorfan likes this.
  10. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    Progress is being made. I have lightly sanded the paintwork and removed the outline. I have used copious amounts of T-cut but still have light scratch marks from the sanding, the paintwork has a slight sheen/reflection but no where near that of the shine of the surrounding paintwork. Should i continue with the T-cut or will an ultra fine wet sand be better followed by more T-cut?
  11. Naraic
    Naraic Moderator
    9,926
    662
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Stop with the T Cut...start with very fine polish now.
  12. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    I have some Autoglym super resin polish, will that be ok?
  13. OP
    flowrider99
    2,196
    532
    Jul 21, 2014
    Your Mercedes:
    Success.....the badge outline has gone. Its not a 100% fix but it is good enough for me. Here is what I did........
    1. Sanded the area with a medium grade sandpaper.
    2. Wet sanded the area with 2500 grade sandpaper.
    3. Halfords Super Fine Finishing Pad.
    4. T-cut smooth out any light sandpaper marks.
    5. Polished area with Autoglym Super Resin Polish
    6. Applied Autoglym Extra Gloss Protection.
    Capra likes this.
  14. Capra
    Capra Senior Member
    1,919
    411
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    W204 2013 C350 CDI Pan roof
Share This Page
