Diagnosing faulty injector w/s203
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Clockwork, Mar 13, 2018.
  1. Clockwork
    Clockwork Member
    24
    Feb 27, 2018
    Your Mercedes:
    None yet
    Hi all,
    On the V6 320 auto is it correct that all 6 injectors need to be taken off and tested to determine faults?
    It currently drives perfectly but a bit smokey on cold starts and everything else has been ruled out so want to address it asap.
    Cost to send off 6 to be tested is almost the same as 6 new ones
    Cheers
  2. bob 6600
    bob 6600 Senior Member
    2,157
    199
    Dec 21, 2010
    Your Mercedes:
    Audi S8 V10, S210 E320 CDI (R.I.P.)
    STAR and possibly some other diagnostic equipment can check injected quantities and if they are in tolerance
  3. Pathfinder
    Pathfinder Senior Member
    815
    13
    Dec 21, 2011
    Gourock
    Your Mercedes:
    Is white or black smoke and what is the milage?
  4. OP
    Clockwork
    Clockwork Member
    24
    Feb 27, 2018
    Your Mercedes:
    None yet
    155k, white/blue but has had alot of work done on it recently. Oil cooler kit changed, new turbo, gaskets changed, oils all changed, terraclean equivalent.
    I don't think injectors have been changed ever. I did think about having them all changed due to mileage to prolong it's life anyway
  5. Pathfinder
    815
    13
    Dec 21, 2011
    Gourock
    Your Mercedes:
    May I ask the reason for the turbo change, was the bearing shot?
  6. OP
    Clockwork
    Clockwork Member
    24
    Feb 27, 2018
    Your Mercedes:
    None yet
    Smoking was the initial reason for check but yes inspection showed the bearing was on its way out. This is all according to the mechanic but he is an mb specialist with rave reviews
  7. Westheath
    Westheath Senior Member
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
    Diesel Bob has a very reasonably priced test service.
    Injector testing:
    Conventional style injectors (not common rail) £8:00ea
    Common rail injector testing £22:00ea
    PD/Unit injector testing (e.g. 1.9 TDI VW) £30:00ea
    A no nonsense geezer as well :)
    http://www.dieselbob.co.uk/injectors.aspx
  8. Pathfinder
    815
    13
    Dec 21, 2011
    Gourock
    Your Mercedes:
    If the turbo bearing was on the way out, it is possible that the piston rings or valve seals are also on the way out, as it was the same engine oil that had been lubricating both surfaces. Could try a compression test on each cylinder.
  9. OP
    Clockwork
    Clockwork Member
    24
    Feb 27, 2018
    Your Mercedes:
    None yet
    Thanks guys
    Diesel Bob sounds good shame he is so far away! I'm in Bournemouth
  10. alexanderfoti
    alexanderfoti MBO Forum Supporter
    10,006
    1,000
    Mar 25, 2010
    Your Mercedes:
    Post them! He has a set of my kubota injectors at the moment.
  11. Pathfinder
    815
    13
    Dec 21, 2011
    Gourock
    Your Mercedes:
    Blue ish smoke issually indicates burning oil. Don't rule out the piston rings and valve seals just yet. Get a compression test done before throwing money at injectors.
Share This Page
