joseph3000
New Registration
- Feb 8, 2010
MB dpf technology uses a pressure sensor to monitor the pressure differential either side of the dpf. also 2x temp sensors, one before and one after the dpf. also 1x lambda sensor mounted before the cat (ie before the dpf). if one were to remove the dpf it is fair to assume that the ecu would notice from temp sensors and pressure differential sensor that all was not well. however it may well be the case that the ecu could be given a new scn (change coding to say no dpf fitted) to run without, ask me in a couple of years!
hi,I have 315 sprinter 2007 falt code 2079 (diesel particulate filter differntial pessure sensoe)engine protection is active,I use star machine,any help
cheers
