Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
Completely confused!
I cleaned my calipers and used Textar Cera Tec ... (same stuff as Pagid) to lube the slider pins. Because it says on the tube "its for brake Caliper slider pins".
Now Discovered its mineral oil based!! ... and their tech dept .. say in wrIting it is "prohibited for use with rubber". So I bit the bullet on all that time wasted cleaning out the bushes and redid them.
My MB dealers parts dept said he was pretty sure, they just used the grey paste on sliders. So when getting the car MOT at another MB dealer, I asked their service department what should I use, they initially said "they didn't know", but checked with a technician, who said they use the grey paste. So I bought a tube £19.
Doing it properly I bought new bushes £22. And replaced one coroded pin.
Pulled out the old bushes, cleaned the bore of the caliper holder, greased it all up nicely yet again!.
I noticed the pins despite being beautifully clean, were not quite as slippery as when coated with Cera Tec, but they did slide much better than originally.
So, I tried to find a tech docs on this MB stuff.
Bluntly because I don't want it degrading a brand new set of bushes! Or swelling the rubber and binding the caliper pins.
OK I think its fundamentally Bostik Never Seeze. But Bostik don't reply to info requests.
But I did see on 2 google posts its possibly Lithium Soap based, with added aluminium and copper?, checking ... Lithium grease has an additive to make mineral oil based grease more slippery?
But is Lithium Soap the same thing as Lithium Grease?
So I rang a third MB dealer, and their service department said "they never grease slider pins".
WTF!!
A lot of Google posts recommend this Permatex
Hmmm yes its synthetic ... but read more and you find its mineral oil based and only for metal,to metal!! Obviously these guys stopped chemistry at prep school!
But hey it is available in the UK.
But from my research the only Permatex product for the job ( and solves all the issues ) is
Quote:-
Permatex Silicone Ceramic Extreme Brake Parts Lubricant protect and lubricates every part of a brake assembly and prevents comebacks caused by irritating brake noise.
-Formulated to reduce brake noise, vibrations and harshness
-Dampens natural vibrating frequencies
-Treated with the latest, rust, oxidation and anti-wear additives
-Fortified with high concentration, high temperature, ceramic solids
-Stays in place, protects at extreme temperatures (-54F – over 3000F)
-Chemical and corrosion resistant
-Will not wash away
-Compatible with most plastics and rubbers used in Disc Brake Caliper systems
-Meets JIS K 2228 with EPDM and Nitrile rubbers
And they do sell it in the USA in £7 tubes, but want £132 shipping!
Anyone know where you can buy this in the UK?
Or
Another option I worked out could be a possible, is
But even that has a few negative reviews because its a Dielectric grease ... hmmm not sure why that matters ..
But I would trust 3M a lot more than all these fancy lying bastards, who hide their tech specifications. More marketing than science.
Also its £49 :-/ too expensive for me ... no small tubes available??
So who has a solution to this?
Surely there are more cars than S Class and CL Classes that use these floating caliper Ate brakes with rubber bushes?
Note part of the slider is exposed to the elements, so imo not greasing them is asking for issues, as evidenced by one pin where the plating had worn through.
If they were like the A Class where the slider is metal to metal, but has a rubber boot tbh I am so ****ed off with this I wouldnt give a toss. OK some protective boots fail early big deal .. replace them. But when the slider goes through rubber bushes if they swell then they will bind the pads!
Interestingly a lot of recommendations for Nappa SIL GLYDE, but people claim this is mineral oil based with added silicone, so its not recommended for rubber bushes. :-/
WTF!!
-Will not wash away
Or
