Dreaded 'ABC Drive Carefully' warning came on...
Discussion in 'Suspension, Steering & Brakes' started by rexemper, Jul 5, 2018.
  1. rexemper
    rexemper Senior Member
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    R230 SL500 - oh yeah!
    Was driving the R230 today, decent run of about 40 miles. Parked up and left it for about 2 hours. Came back and started it and got the red 'ABC Drive Carefully' warning. Drove it for about a minute till it was safe to stop, warning was still on dash.
    Switched it off and then re-started (didn't lock the car or wait 2 minutes etc.) and car started normally with no warning on the dash.
    Drove back with no warnings coming on, but kept the speed quite low just to be safe.
    Got home and waited for car to cool down a bit and then checked the levels - the ABC fluid shows as in-between the hot and cold marks. Fluid is still quite green in colour.
    So, should I just top up the fluid and monitor it or is it likely that its something else/more expensive?? Is it normal to lose fluid?
    PS I thought there may have been more of a pump type noise from the car when driving at very low speed/coasting but that could just have been paranoia or the fan blowing to keep the engine cool.
  2. LostKiwi
    LostKiwi Senior Member
    12,161
    4,215
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    If you have access to a code reader there may be a stored error code which will gives pointer. I'd also check ABC pressure in the live data.
  3. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks. I don't have a code reader. Looking back through an old thread I posted on about ABC fluid levels and mine was just under the 'Unladen' mark so it has dropped a little since then which was over a year ago.
  4. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Just reading the sticky about the ABC system and reading the part about checking if the level drops when the engine is on compared to when it is off.
    Just wanted to check something - checking the ABC fluid level with engine off is fine - as in I can do that. Checking with the engine on, is there a recommended procedure for doing this? Should I check with it off, replace the dipstick and cap, start engine and check again. Or should I check when its off and then just start the engine with the cap off? Just want to minimise the risk of doing any damage / something silly.
  5. Craiglxviii
    Craiglxviii Senior Member
    12,040
    2,079
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Garage Queen; W211 E320 Avantgarde Estate Designo Edition
    Engine on, pull dipstick up, check level, wipe with clean rag, check again, replace dipstick, clean up any drips. Fluid level should be within the notch of the lower mark.
  6. John Laidlaw
    John Laidlaw Senior Member
    14,621
    3,005
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Might help visually ( not a 230 but principal is the same)
    However....get codes read quickly it’s just not worth the risk
    When my pump went there was a cavitation noise with the roof down at low speed - this was when I was crawling to my Indy slowly but by then it was obviously too late. And that with no dash warnings!
    With dash warning I would be even more concerned !
    Sorry rant over ...
    rexemper likes this.
  7. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks.
    Thanks John - I recall yours being a very expensive repair!
    Just checked with engine on and the fluid is about halfway between the lower mark and the bottom of the dipstick. So obviously needs fluid in there. Is it worth getting some and topping it up whilst I get the codes checked - which won't be till next week now?
    If so, where is a good place to buy some? Somewhere I can drive to or will deliver quickly would be good.
    Will get the codes read for sure. At least the warning hasn't reappeared yet.
  8. LostKiwi
    12,161
    4,215
    Aug 25, 2006
    Your Mercedes:
    GSF do Febi's Pentosin. If you get one of the weekend special codes it's about £7 per litre...
  9. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks, will try them.
    Is it the CHF11 that I need?
  10. LostKiwi
    12,161
    4,215
    Aug 25, 2006
    Your Mercedes:
    That's the one. CHF11s
  11. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks. Can't see any deals on at the moment so might wait for the weekend to kick in just in case.
    No difference between Febi and any other brand I take it? I thought Pentosin was the actual brand.
  12. LostKiwi
    12,161
    4,215
    Aug 25, 2006
    Your Mercedes:
    Yes Pentosin is the brand. The febi stuff is the same spec.
  13. John Laidlaw
    14,621
    3,005
    Nov 15, 2013
    Wirral
    Your Mercedes:
    And just make sure when you pull the dipstick out nothing falls in ...
  14. John Laidlaw
    14,621
    3,005
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Halfords are doing one from £14 a litre, there are loads selling it
  15. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks John.
    Plan is to buy a litre and top it up and then find somewhere to get the codes read. Best to get it on Star or will a more generic reader give some insight as well (as in from a non-specialist)?
    I'm crossing my fingers and hoping that the lack of the warning's reappearance is a good sign.
  16. John Laidlaw
    14,621
    3,005
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Fingers crossed!
    The icarsoft can read ABC issues not sure on others but anyway best get it on Star it’s worth it to be sure. Ian at Star in Caversham comes to mind
  17. LostKiwi
    12,161
    4,215
    Aug 25, 2006
    Your Mercedes:
    As John says Star will gibgthe most definitive answer. You also need to find why the fluid level dropped.
  18. SL55 Mark
    SL55 Mark Senior Member
    2,238
    54
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    This ^^^ is correct. The only time my ABC fluid level dropped was when I had a fluid leak. Other than that, it has not dropped at all in 6 years. I believe you have a leak which will need finding and fixing as soon as possible, I would not drive the car until the cause is found.
  19. OP
    rexemper
    565
    19
    Jan 5, 2007
    Berkshire
    Your Mercedes:
    Thanks. I have noticed there is also a rumble type noise from the front passenger side when at low RPM - goes away when you accelerate. Reading the sticky about the ABC system, it points to the pulsation damper failing. I haven't had the warning come up again since topping up the fluid, but I'm not really driving it much till the guys at Star have had a look - which should be on Thursday.
    Fingers crossed and will keep you updated.
    Flyinspanner and SL55 Mark like this.
  20. SL55 Mark
    2,238
    54
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    Not wishing to set any pigeons running, a rumble type noise from that area can be the sign of an ABC pump failing, which was what happened to me and caused my leak. The ABC pump is on the front passesnger side of the engine (in a RHD SL55, anyway). Hope it is nothing too serious for you.
Share This Page
