Vehicle E Class tailgate issue
Discussion in 'Mercedes Car Classifieds' started by goldy, Dec 19, 2018.
Tags:
  1. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Will do.
    Fingers crossed!!
  2. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Oiled again with 10/40 oil. Couldn't be sure what the garage gave me and it had issues again. All operating fine again. Hopefully it will last this time.
    Thanks again
  3. malcolm210
    malcolm210 Senior Member
    3,067
    294
    Aug 21, 2005
    I’ve found fully synthetic oil best, glad you’re having some success with it, mine was just the same as you’re experiencing and works well now with the aforementioned oil
  4. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Mechanic in the road has suggested furniture polish sprayed on the hinges and ball joint. May be a future try. Can't see it mixing with oil
  5. malcolm210
    3,067
    294
    Aug 21, 2005
    Interesting comment by your neighbour but not sure it would help especially as I don’t recommend mixing compounds, I’ve found full synth oils seem more resistant to water which is the main enemy in this case
  6. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    There seemed to be a lot of play in the ball joint connecting to the motor but more concerning was the noise. Very clunky like metal on metal. Squirted shed loads of oil in that.
    Often made a banging noise when coming to a stop fully open. That seems to have subsided now.
    May be getting somewhere at last!
  7. malcolm210
    3,067
    294
    Aug 21, 2005
    Pleased your seeing some improvement at last, a real test of anybody’s patience, I think I’d rate the design 2/10
  8. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Think you're being generous with a 2!!
  9. malcolm210
    3,067
    294
    Aug 21, 2005
    Lol, keep us informed I really do hope you’ve sorted it I know from personal experience how frustrating it can be
  10. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    I will keep you informed.
    It's so frustrating, especially when the dealers are messing me about.
    Glad somebody understands the frustration.
    Thanks again for your help.
  11. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Well that didn't last long! Failed again. Groaning then stopping after a few inches.
    Losing the will!!
  12. malcolm210
    3,067
    294
    Aug 21, 2005
    Damn I thought it was sorted!
    Four choices now:
    1 - keep oiling it daily for a couple of weeks to see if it improves
    2 - use penetrating oil on the balljoint and hinges for a couple of days and then reapply lubricant
    3 - if 1 & 2 fail have the hinges, balljoint and motor removed for inspection and the tailgate checked for alignment
    4 - write to MBUK and outline events somebody needs to take some responsibility/ownership of the problem.
    I’d probably do 4 first and persevere with 1 and 2 until MBUK get back to you, just remind MB about their ‘best or nothing’ slogan, the problems you are experiencing are not acceptable from a premium brand
  13. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    MB have accepted the lies from the dealer and sided with them.
    Dealer says all aligned and correct.
    I've oiled again. Letting it soak in now.
    Bizarre thing is after it failed it operated fine for about 10 openings.
    So so frustrating.
    If it was not aligned properly would it not fail every time?
  14. malcolm210
    3,067
    294
    Aug 21, 2005
    There is obviously some resistance in either the hinges or balljoint still there. If you can leave it shut for a few days and keep adding oil each day it might allow the lubricant time to work it’s way in, that’s what I do if it refuses to open, which hasn’t happened for 6 months now
  15. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    After I oiled it the rain came down. Oil slicks down the driveway. Ridiculous amount of water passes over the hinges and ball joint.
    Emailed CEO.
    Yesterday it was smooth as after oiling. Got to be down to lubrication surely?
  16. malcolm210
    3,067
    294
    Aug 21, 2005
    What’s the timeline from the accident to where we are now, who was the insurer and where was the vehicle repaired?
  17. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Accident was July 2017. Insurer Aviva for both myself and third party.
    Repair done by Marshall Mercedes Blackpool. Bought from Marshall Preston. Both blame the other for the fault!
    Blackpool took apart and put back together in December. Say all good and have put in writing it isn't accident or repair related.
  18. malcolm210
    3,067
    294
    Aug 21, 2005
    If the car has full MBSH you stand a better chance of some sort of goodwill from MBUK if the problem persists. What’s puzzling me is why the tailgate functions normally for so many cycles and then stops, as you say there is enough lubrication present to rule that out and it does start to sound more motor related.
    You could try resetting the position of where the tailgate stops by pressing the close button (see the manual for this) to see if that makes a difference.
    A lot of modern drive mechs on cars nowadays are fitted with plastic gears so it might be that the motor gearbox has been damaged, either a cracked gear or missing a tooth
    This is the motor
    https://www.ebay.co.uk/itm/MERCEDES...762578&hash=item3d554387d9:g:JMAAAOSwr6FaHlNz
  19. OP
    goldy
    goldy Senior Member
    64
    Apr 11, 2008
    Motor was replaced about 6 months ago so the dealer says.
    Car has FMBSH and is under extended warranty.
    There's been that many attempts to repair it it's a joke.
    I was hoping they'd missed the simple thing and thought the oiling was working.
    Marshall Mercedes have lied to Merc customer service constantly so they keep closing the complaint.
    They also say all they can do is liase with the dealers, they can't make decisions.
    Ive referred to the motor ombudsman too so I'm waiting for them to contact me.
    Just opened it manually after it stuck and the noise is awful. As if it is dry and resisting.
    Then closed and opened it. Opened perfectly without a murmur.
    It's beyond all logic.
  20. malcolm210
    3,067
    294
    Aug 21, 2005
    I’d push for MBUK to send one of their engineers over to look at it as the dealership(s) haven’t been able solve the problem. I’m really surprised that your local MB franchises have washed their hands on this I find it astonishing it’s basic engineering and shouldn’t be that difficult to fix
    I think your only option is to keep pestering MBUK, you have a warranty in place so they should fix it, if they can’t they should be offering an exchange vehicle
Share This Page
