E270 cdi 2005 alternator
david ash
I have an estate version E270 cdi from 2005 and need to replace the alternator but does anyone know if that model is water cooled?
Hello David and welcome,, yes the 612.962 usus a water cooled alternator
m.mycat
rpe2
Silchester
If it is the regulator pack on the back, i think these can be bought seperately
I was going to say that but not sure if this applies to some of them, I know that on some you can,, interesting that nothing ever in WIS on this subject
D
david ash
Hello and thank you for that Malcolm and Richard.
I suppose I should have said that the reason I am going to replace the alternator is because I get a fault message that tells me there is a problem with it.
Which is backed up by the battery refusing to charge while driving the vehicle.
I have tried , in vain, for months to locate a regulator.
So to replace the unit looks like the only alternative.
Do you think that is the right way to go?
S.Speed
Lancashire
Older Citroen Now :-(
Be warned..
Water cooled Merc alternators cost a fortune..
I had forgotten that I had the alternator replaced on my E320 Cdi (under warranty) and the bill was £880 !!!
Bring back the days of a £45 Alternator rebuild !
Be warned..
There are some good firms Simon that fix them as in two of my links
D
david ash
Thanks again for the information.
Malcolm I'll try those links and see what I come up with.
£880...ohmigoddd !
I'm working in France at the moment and the local garage quoted me a price of over 1200euros plus delivery which is why I'm planning on doing it myself.
I have been offered alternators which they said were the correct part..however once I mentioned it should be water cooled the conversation stopped!
Thanks again for the help.
Any further thoughts will be greatly appreciated.
David
If you would like the fitting instructions I can send them to you
D
david ash
Malcolm that would be amazing !!
David
I need an Email address please you can edit it out within 4 hours.
I will send the outline paper plus another, there is an in line fuse on this and worth checking out.
Other papers can be sent later
The main papers have been sent, you can edit out your address
tode
NW FRANCE
S350 btec 2011
Where abouts in France are you, David ? And what make is the alternator ?
1200€ does seem an awful lot, even for a Mercedes ;)
D
david ash
Hello Malcolm wasn't sure how to do that and I thought you weren't supposed to edit posted mail???
I am new after all.
I am in the Loire valley near Angers.
And the part is by Bosch.
And I thought 1200euros was excessive too.
However I also have a Land Rover (disco 2) and wanted to change the headlights over and was quoted 1000 euros for that here!
But I had Britpart ship a pair for £250 inclusive.
David
Alex M Grieve
Broom, Warwickshire
The one's you have taken off will be worth a price too - either now (if you don't plan bringing it back) or in due course when you change back on return to the UK.
D
david ash
  • #18
Yes I thought that so have them carefully stored.
tode
NW FRANCE
S350 btec 2011
David
I don't know how far you are from Le Mans, but I always used to use LE HELLO, who were always very helpful, and usually managed to find cheap(er) solutions, and good on repairs, too.
Their phone numbers are:
Magasin V.L. 02 43 783 785
Électricité auto 02 43 783 783
It's worth a try, you may be surprised.
How's your French ? If you like, I could try phoning them (if you give me the Bosch number.
D
david ash
  • #20
About an hour away from Le Mans.
My French is ok but If I run into any problems I might take you up on your kind offer.
David
