james2747
- Jan 26, 2011
- Location
- Newent, Gloucestershire
- E270 CDI 2003
I am trying to replace a broken rear spring on my recently acquired 2003 E270 CDi.
I'm following a guide which tells me to unbolt the suspension arms at the hub end, remove shocker to swing arm bolt … then loosen the inboard swing arm to subframe bolt (the one, that goes through the large rubber bush … see photo) which enables you to lever the loosened swing arm down and remove the spring.
All went well till I attempted to loosen the swing arm to rear subframe bolt … the nut came off ok but the long torx bolt just wouldn't budge. I assume it is the original bolt that could have been in position for nearly 15 years now …. although looking at the service record that came with the car, the rear springs were replaced by Mercedes in 2009.
Gave it lots of releasing fluid plus some hefty bangs on both ends with a hammer to try to break any corrosion holding it …. plus lots of force applied trying to turn it, such that I could feel the torx grooves yielding as I applied maximum force using a torx socket and breaker bar.
I assume the bolt is corroded on to the swing arm as there is no movement at all.
If it was just seized inside the bush then I assume I would rotate a little as it would move as the rubber bush compressed round … but zilch … it just doesn't budge at all.
I didn't want to really force the swing arm down without loosening the bolt as it may damage the rubber bush so I had to put everything back together and try another day.
Will still need to remove spring in not too distant future as it won't pass MOT with a bottom coil snapped.
I assume I'll end up destroying the bolt before I can get it out so as a precaution I bought a new torx bolt today which cost £9 from Gloucester Mercedes!!!!! (yes a 12mm dia. torx bolt … what a rip-off).
Anyone had a similar issue with this bolt or any suggestions on how I could remove it.
