ColeS210
I'm having problems with my S210 e320 cdi (200k miles), it's seriously lacking power. The car will accelerate quite normally up to about 30-40 miles per hour but then just seems to really struggle to gain speed. The car doesn't want to rev up and has no power top end, it struggles to rev up over 2.5k rpm. Even when driven in manual mode the car struggles to rev up which makes me think that it isn't a transmission based problem. The kick down also isn't working and causes a warning and malfunction to be displayed.
The car produces black smoke under heavy load also.
When checking error codes, nothing comes up apart from the direct sunlight sensor which is unrelated. The car was recently serviced and the MAF sensor was changed a couple years ago.
I took it into a garage and they said to run a fuel system cleaner through it and give it a good run but this hasn't solved the problem at all.
Hoping someone has had a similar problem and can help me out in finding what the problem may be.
Thanks,
Thanks,
