E350 aircap stuck
malty123
Nottingham
E350cdi sport 2011
I have a 2011 e350 cab and the aircap is stuck in the down position and no lights illuninate on the switch.
I took it to the dealership yesterday who plugged it into the diagnostics. They say the actuator motor thinks the aircap is open eventjough its closed hence not working. And only fix is a replacement unit at 1400 quid.
Any ideas if this can be fixed without a replacement and 1400 ?
V6Matty
Newark, Nottinghamshire
Personally I wouldn't take it to the dealership, try having it looked at by an Indy, i have used MB Centre for years and trust their advise
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
1400 for the airscarf? I'd wear a hat instead...
M
malty123
Nottingham
E350cdi sport 2011
Exactly, thats why im seeking advice on how to fix it myself, i will wear a hat in the meantime
M
malty123
Nottingham
E350cdi sport 2011
Has anyone got a wiring diagram so i can unplug the aircap and apply voltage to the aircap connector to try to raise/ lower it manually in an attempt to reset the position so the ecu recognises it closed rather than open?
M
malty123
Nottingham
E350cdi sport 2011
Any help on this one appreciated
Alldar
Registered
E Class cabriolet/2010/E200
I have an aircap stuck in the open position...it goes down but then opens again.....annoying......I am currently trying to find out how to reset it....but, when trying to find this out I ran across a video on You Tube on how to remove the aircap "replace air cap"......it shows the connector in the overhead console etc......it may help.
M
malty123
Nottingham
E350cdi sport 2011
Did you ever fix this?
M
malty123
Nottingham
E350cdi sport 2011
Or can anyone offer any advice
Daniel_Martin1990
New Registration
A207 E Class 250 CDI
Hi All,
Did anyone ever get to the end of this?
I have got a 2013 and have got the same problem currently.
Cheers in advance
Dan
Unininaninimity
14allu2cMartyme2408
I have a similar issue. I am going to try a software update first to see if that has any effect. Will update you later.
