I have a E300TD R reg and, believe or not the drivers window did exactly the same thing last year! I ended up putting it in to the local dealers who re-aligned the window runners. Everything OK since then
I have a '98 R E430 and the nearside rear window did exactly the same thing, but I managed to correct it by 'wiggling it' from the outside while Mrs Pat operated the switch. I've tested it about a thousand times since and it works perfectly!
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
