- Mar 25, 2010
- Location
- Tonbridge
- W221 S65 AMG - W204 C63 AMG + Various other MB's
- Moderator
- #1
Hi all
On my motorbike I have a Facet fuel pump fited.
A facet fuel pump has a piston internally which is balanced against a spring. An electromagnet pulls it towards one side, where it then disconnects the electrical connection and the spring pushed it back the other way.
In normal operating it clicks at roughly 40hz. This pulsing load on my electrical system causes by dashboard LED's to flicker (as they are sensitive to voltage fluctuations).
Its not a wiring fault as it does the same when wired directly to the battery.
I have thought about putting a capacitor across the pumps power wires but cannot figure out if I need a massive capacitor to smooth the pulses?
Ideas?
Ideas?
