Hi,I recently bought E250CDI (automatic) and noticed strange vibrations under driver seat, and quite noisy engine ? or exhaust maybe, under load 1500-2500 rpm,nothing on idle not shaking or vibrations at all.One more thing when engine is started and if i change gear to reverse i can feel engine movement inside, and this also happen when i change gear from revers to drive but not as much when is going from park to reverse.I recorded short video which shows engine behavior when gear is changed and when i tried test engine mounts using brake and accelerate method at same time.
at 0:15 change gear from P to R
at 0:18 change from R to D
and after that i done test accelerating and braking
