- Aug 25, 2006
- Location
- Midlands / Charente-Maritime
- '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi
Bush engineering80c seems about a std target, smaller flow, smaller rad ,more temp if you want to use motor at higher output.ie more heat. a compromise will need to be found.put a 2inch ball,gate valve in and try strangling the flow until you find that compromise then come up with a permanent version or make yrself a winter summer, poodle and flat out running.. setting on the valve handle.
i ran a water cooled 6cyl detroit on a water pump with no rad for more than ten yrs i took a bleed off the 6inch water pump it was running to a large tank about 600 lt. then i closed down a gate valve from the engine to the tank in such a way as to keep the capilary guage at 88.excess water returned to pump suction. worked great.only issue 2x a yr cleaning river silt from the tank
