Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
My thoughts .. And a sort of mini review
£99 reduced from £136
So its not a Pro tool, but not a dirt cheapo job
Alledgedly accurate to 2 microns.
Hmmm ...
thought it was broken when I tried the boot ... I assumed it was Ally.
Ooops its plastic can you believe that??
This meter only does Ferrous based and Aluminium, I knew that, but really would have liked to know the boot thickness.
Bit of a blow to find the boot was plastic.
Do expensive meters read paint thickness on plastic bumpers and skirting components?
Its quite difficult to get consistent readings, as you have to press it down very accurately i.e. at 90 degrees. As you press the spring loaded ball down, you know when you are off, as the surround makes contact i.e. If its not square. Obviously thats more difficult on a curve.
But you can repeat it and once you get the right angle the readings become consistent.
MB say paint should be between 80 to 130 microns. Mine is generally around 125 microns, with a few areas mainly concave curves climbing to 132 micros
Apparrently resprayed areas often are about 200 microns (well thats when Mobilo Warranty start investigating if you have had paintwork done) , ... nice to know I dont have any of those.
The bonnet is circa 119 to 121 microns, as is the roof top.
Was this due to a previous machine polishing? Or are they polished at the factory?
Having had 6 S Class level cars new, I have noticed the Bonnet is always more glassy than say the sides (the latter can have what one might call almost the start of orange peel, but not that bad).
Or it could easily be my measuring angle accuracy or the fact I havent recalibrated it (which you can do).
And I can see a few areas like in the concave curve on the back arches that can read up to 132 micros. I am assuming, thats due to the curve making the reading slightly bigger i.e. difference between the ball point pin and the circular surround being a tad longer. Or maybe paint collects more in the “well shape” when factory sprayed.
But as it has similar in readings, in exactly the same area on the other wing, and the glass like quality of the paint being so MB looking: I am pretty sure its not a resprayed area.
OK I got lucky, but this would be a useful tool when checking a second hand car.
The original owner did certify it had not been in an accident and had had no paintwork, other than one cill, and part of the other cill due to road grit rash ... reasonable as I also collected a few micro pin hole chips .. due to the wheel overhanging the skirting (really needs mud flaps) .
So in summary, is it useful for machine polishing? .... interesting question.
- without knowing the cars history from new; The best one can say is if the max readings were 125. Then clear coat should be 40 microns. So one could assume you would go through the clearcoat at 125 - 40 i.e 85 Microns. So if the bonnet is averaging 119 ... one has circa 24 microns min.
So as it looks great with 24 microns I would go easy polishing there. I.e. looking to remove no more than a micron.
Of course this is just supposition, because it could still have 40 microns of clear coat due to a flatter base coating. Or it could be the opposite, namely being a flat area more paint should “lie” there and someone has machine polished the crap out of it! lol who knows!
Being a cautious bugger ... I would assume the worst and just use this tool to say .. right it could be thinner here, so limit the polishing to a very minimum and try to virtually take nothing off!
So Yes imo its a useful tool:
- to alert you to potentially thinner areas
- and to check you are not thinning it (especially if using a given polish and a pad for the first time). To me as a novice polisher it will give me a lot of reassurance to see zero to 1 microns removed if I polished an area.
- Also might be useful when buying another old car. Just to see if it had bodywork.
The negatives are it cant measure plastic bodyparts
- but then I am far more interested in clearcoat thicknesses over Ferrous metal panels ref rust protection.
Would I go out and buy one .. if say I hadn't had my cement dust issue?
No, because I wouldn’t do a machine polish.
But in this case, as it was paid for by the Builder who caused the damage. Yep glad I forced him to pay for it. As it gives me reassurance I don't thin the clearcoat in potentially thinner areas.
Well knowing what I now know, i.e. that the paint on the bonnet is apparently near 119 Microns, I will check my sister bonnet ( New S Class AMG ) to see what the reality is.
Hope this mini review helps others
Hmmm ...
