Duke907
- Jan 22, 2017
- Location
- Edinburgh, Scotland
- SLK 320 2002
Hi all
I have a recurring issue of the ESP / BAS light coming on in my 2002 SLK 320.
After using a icarsoft obd reader I replaced the rear N/S speed sensor.
Now the error that comes up is...
Pressure sensor : zero point offset error for component B34/2.
When you look at the live data the pressure is registered ok and changes as you press the break.
When you lift off it goes up to 255 psi where the sister sensor B34/1 sits at 4 psi.
Does anyone know if the zero can be set? Or the system re-calibrated?
