jj1975
On SAS small gear will should show yellow tooth line in picture
Clock spring to be in centre position should aloud to make just over 2
full 360 turns both ways left and right
After you make sure they are in centre position joint together cerfully and put
the part as 1 to steering column and everything else
After putting everything together start the car do 3 times turns lock to lock
Turn it off take keys
Start car again and go for a short drive and this should fix
If not you part is faulty
