smart_mart
- Jan 28, 2014
- Location
- London, Middlesex
- c200/2006/2.2
Hello, I'm hoping someone could help me with a few problems I'm having with my Mercedes c class sports coupe 2006 diesel.
I've had the car for a few months and have had trouble with it from the start.
I first had to replace the conductor plate because of oil leaking. I got a diagnostics done and the air mass sensor needed replacing also so I did that.
After replacing these two things I was still having trouble with loss of power to the engine ; when I am accelerating I have my foot down all the way but the car will not pick up speed. Sometimes there is black smoke coming from the exhaust.
I was told the ecu might need reproramming from a Mercedes dealer. I have already spent quite a lot on the car and was hoping someone could advise me on the best thing to do.
I have 3 fault codes that are showing however I don't know if one fault is causing the other 2 or do I actually have all these problems?
I have attached the print out of the fault codes.
I would appreciate anyone's help. Thanks
