cubbyq
- Aug 17, 2017
- Location
- Gloucestershire
- 2013 E220 CDI SE Estate
- Thread Starter
- Thread starter
- #21
Morning Frosty,
Thanks, and it's re-assuring that I'm not imagining this!
And thanks for the advice on the tyres, and it was my first thought yesterday too, checked and they were up 1psi all round, so just dropped them to where they should be. Once I get the car back and working, I'll experiment with the lower tyre pressures. The rears are hardly worn and have even wear, however try fronts are a little more worn and quite worn on the outside edges, so that could contributing to the steering (the alignment was out when I tested it and they've obviously sorted that out as it drives straight now apart from the constant adjusting on the uneven roads).
Like I said in a previous post, it's the way issues are handled, and the dealer seems genuinely concerned at what's causing the problem and are wanting to put it right...
It's a used car, and every used car has it's problems, so not throwing my toys out the pram, it's just frustrating - I think If I'd not bought it from a main dealer, then I'd be in a different situation!
Cheers,
Nick
Cheers,
Nick
