Front end knocking.
Discussion in 'Suspension, Steering & Brakes' started by onefortheroad, Dec 6, 2018 at 3:44 PM.
  1. onefortheroad
    onefortheroad Senior Member
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    Up to date I've changed every front arm and ball joints in the hub, plus arb link arms .both front shocks and top mounts my knock still exists over small repeated bumps on uneven roads. It doesn't make a sound over speed bumps or bumps at speed. Which kinda tells me it may not be the arb bushes,Has anyone had issues with the top horse shoe shaped mounts and the end ball joint , can you remember the metallic rattle and what did you change to cure this. Thanks.
    2008 CLS w219.
  2. gassed up
    gassed up Member
    22
    9
    Jul 2, 2006
    liverpool
    Your Mercedes:
    2011 C207 350CDI;2010 C207 350CDI sport;2010 SLK300;2004 C209 320;2000 C208 230K;
    I had a metallic rattle from the suspension on my C209 which had me stumped for about 3 years. Only found the cause when I stripped the rear suspension for a rebuild, transpired that the last 50mm of one of the springs had snapped off and was rattling in the spring pan. It couldn't be seen until the lower wishbone was removed.
    om613 likes this.
  3. Botus
    Botus Senior Member
    2,506
    349
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    what about the actual bushes holding the arm to the car? oddly true - most noises start here
  4. Uncle Benz
    Uncle Benz Senior Member
    2,230
    333
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    You've probably replaced them, but the balljoints that the arb drop links attach to, the ones pressed into the arm, are notoriously difficult to diagnose.
  5. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    I was going to detatch both arb links and drive it. If noise remains . its not them . looks like the bushes are bonded and you change the whole arb ..
  6. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    Changed the whole arm. But thanks.
  7. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    The only other thing is the strut track arm ball joints . maybe better off replacing the arms plus ball joints . if it stick knocks . its a vw tiguan on the drive !!!
  8. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    Today I took both arb links off and the rumble sound is still audible. So I'm ruling out the arb bushes. I've ordered both sides upper mounts and will fit those and see if things improve. Last chance saloon .
  9. malcolm210
    malcolm210 Senior Member
    2,971
    261
    Aug 21, 2005
  10. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    Unlikely , its more uneven ground that causes it. I can rev the engine and its fine.
  11. OP
    onefortheroad
    686
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
Share This Page
