Fuel line washers
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Jonathan Lingham, Apr 16, 2018.
  1. Jonathan Lingham
    Jonathan Lingham Member
    22
    Feb 6, 2008
    Your Mercedes:
    W203 CDI auto Estate, 2002, 2148cc
    image.jpeg I can't restart my 220CDI after changing the high pressure fuel pump, even if I turn the engine over for two minutes continuously, and drain a fully charged battery. After trying I can see bubbles rising in the vertical fuel pipe on the front of the engine.
    I'm gong to try replacing the two squishy white washers on the fuel feeds into the pump, to see if that helps, but I'm having problems finding them online. Can anyone tell me what they are properly called (or better still give me a part number), and recommend a supplier?
    Thanks.
  2. mersum1es
    mersum1es Senior Member
    1,626
    59
    Sep 25, 2010
    Finland
    Your Mercedes:
    W210/-01/270CDI, W220/-01/320CDI, EX:W211/-04/320CDI
  3. Taffy7hfa
    Taffy7hfa Senior Member
    669
    95
    May 29, 2016
    Oxford
    Your Mercedes:
    ML 270CDI, 2002, Fully loaded. 2014 Peugeot 308 1.6 HDI
    I don't think the foamy washers do very much really, the seal is made by the O rings, fuel system is a tw*t to bleed though, save your battery/starter motor and try a little easi start straight in the egr valve ;).
    Jonathan Lingham and om613 like this.
  4. OP
    Jonathan Lingham
    22
    Feb 6, 2008
    Your Mercedes:
    EGR valve?
  5. OP
    Jonathan Lingham
    22
    Feb 6, 2008
    Your Mercedes:
  6. om613
    om613 Senior Member
    1,213
    225
    Aug 29, 2015
    london
    Your Mercedes:
    S202 C250TD, S123 240TD
    You don't need them, just squishy foam...
    Jonathan Lingham likes this.
  7. Taffy7hfa
    669
    95
    May 29, 2016
    Oxford
    Your Mercedes:
  8. OP
    Jonathan Lingham
    22
    Feb 6, 2008
    Your Mercedes:
    Interesting.
  9. OP
    Jonathan Lingham
    22
    Feb 6, 2008
    Your Mercedes:
    OK. I bought some easy start and tried again. It sort of caught, and ran for a second or two, then died. I kept trying, using up half a can of Easy Start, and drained the battery. And now the Electronic Power Control has come on. Any advice?
  10. om613
    om613 Senior Member
    1,213
    225
    Aug 29, 2015
    london
    Your Mercedes:
    Something wrong, then.
    One or two sprays into the air intake should be enough to start it, which will then bleed all the air out.
    You didn't mix up the two pipes from the high pressure pump, did you?
    Westheath likes this.
  11. Taffy7hfa
    669
    95
    May 29, 2016
    Oxford
    Your Mercedes:
    It must have issues other than just air in the system then, next step would generally be a leak off test or get some live data from the fuel rail to establish whether there is sufficient pressure in the rail to run the injectors. your going to need a properly charged/new battery for both of those.
  12. Westheath
    Westheath Senior Member
    1,256
    337
    Nov 6, 2015
    South London
    Your Mercedes:
    The old swicherooooo.............
    Check pipe works correct.
    om613 likes this.
  13. OP
    Jonathan Lingham
    22
    Feb 6, 2008
    Your Mercedes:
    No, I’ve been very caref
    No, I’ve been very careful. Do you know what is likely to be triggering the EPC warning?
Share This Page
