Merc Driver C220 CDi
- Aug 11, 2017
- C220 Cdi Estate Manual 2012
I own a 2012 C220 cdi sport estate now 60k manual
About 9000 miles ago the cutch flywheel and release bearing were changed due to cutch judder or so I thought, all seemed fine until I went to Europe in June (6 months after the clutch was replaced), on the return journey I noticed a small judder when pulling away in traffic on the M25 but didn't take much notice, this has steadily got worse as time has gone by. The car has been returned to the garage who changed the clutch who have said there is nothing wrong with the car, now driving it regularly you know how the car runs and i'm telling you there certainly is !!
When the engine is cold it starts and drives ok but not as I think a Merc should, sometimes when ticking over the revs drop and then regain about 800rpm as they should be, it is very snatchy, when at car park speed in 1st or 2nd (usually 1st) you can get a "kangaroo" effect not smooth 10 mph as usual, it's a little flat on acceleration and mid range a slight mis fire when accelerating and decelerating maybe described as lumpy and then when you have driven aprox 70 - 100 miles and the engine is hot every time you start off from a standstill the famous judder !! which actually differs in severity, sometimes not noticeable other times shakes your teeth loose.
Now my question, could there be a fuel regulator that may be knackered or similar, or is this just how they run (I hope not as its pretty **** for a car of this quality I believe) or has the clutch failed again at 9000 miles since changing (REALLY).
I have posted this before but just asking about clutch judder.
The car has been on a diagnostic but nothing showing but as a driver you know its not right.
I did ask someone else to drive the car and they agree with me it doesn't appear to be running properly and in his words "certainly not hoe he imagines a 60k c class should"
Any advise would be welcomed
