smb
- May 23, 2012
- Location
- South Africa
- 1994 W202 C220 Auto
Hi there
I've got a 1994 C220 automatic (W202) and have a few questions about a relay (p/n 0015429619), which I assume from Google searches is the fuel pump relay. If you follow Dec's post (http://forums.mercedesclub.org.uk/showthread.php?t=62702) about the solder repair of the N10 relay, then the relay I'm talking about sits just to the right of the N10 relay. (Those slots are empty on Dec's photos unfortunately, but you can see those locations on Pics A&B).
Anyway I'd recently purchased this car and while going through the repair job on Dec's post, I noticed that there is a fuse which sits on top of the fuel pump relay and it was blown - and also that it looked brand spanking new (ie recently replaced). I was concerned about a brand new fuse getting blown (cos this means an expensive electrical fault elsewhere) and took it out for replacement. Only when I was about to put in the replacement did I spot that on the relay, it is clearly marked "12V 30A". And the replacement fuse, and blown original fuse are both 15A.
Now I suspect that the reason the fuse blew in the first place is cos it was a 15A fuse which was inserted where a 30A fuse should've gone. This was probably the doings of the Dodgy Dealer that sold me the car in the first place. So now I've got a few other questions to ask - hopefully someone can shed some light.
1) Should I replace the fuse with a 30A or a 15A?
2) Is there a diagram or card which actually shows the correct amperage fuses for my model? (The card in the fusebox tells me what the fuses are for, but doesnt give the correct amperage, so I'd have to revert to the Dodgy Dealers decisions and just replace with what was there before).
3) What does this relay actually do: I've seen it called a Fuel Pump relay, and also a Multi purpose relay. What other purposes does it have?
4) I've been driving the car for about 4 months and have only recently spotted this blown fuse. I've since driven it a further ~week with the blown fuse. Is it possible to do use this car without a fuel pump for >4mnths, under normal circumstances (ie: Did the Dodgy Dealer short-circuit something to make the relay work without the fuse?)
Thanks,
Thanks,
