fuse 41 location w210
moore_887
Cork Ireland
Hi all,
No indicators or hazard lights on 1996 w210 e230. Have fuse list from 99 e220cdi. Says 41 for turn signals. Cant find fuse 41. fuse box under bonnet only goes up to 18. Fuse box beside lights swithes under cover have no numbers at all. Fuse box behind battery under bench seat drivers side has its own list of fuses.
Have i missed out on a fuse board somwhere?
thanks
Fuse 5 in block A
M
moore_887
Cork Ireland
Thanks television. Just checked fuse 5 under the hood, Blue 15 amp fuse looked ok but i changed it anyway. indicators and hazard lights still not working. We repaced the wiper motor and the heating controls from a crashed 99 e220 cdi. All the other electrics on the car seem to work fine.
See what I can find later, did these things ever work after changing the wiper
M
moore_887
Cork Ireland
No. I didn't try the indicators until after several miles of driving. I switched over the wiper motor and heating controls just before lunch today.
M
moore_887
Cork Ireland
I got that sorted. I decided to take back out the heating control box as i know there is a slight difference between that one and my old one (small light down the bottom right hand corner of the recerculate switch that reads REST). It was then that i noticed that i had never reconnected the connector block for the hazard warning lights, headrest drop and central locking.
Thats what you get for trying to do things in a hurry!
Thanks for flashing up the indication of your fault
