Thank you it's 7 speedHi and welcome.
It really needs a session on Star to pull off error codes. It may be the electronic plate in the gearbox or may be worn internal clutch packs. Is it a 5 or 7 speed?
Fairly common problem with the 7 speed is failure of the speed sensor plate (turbine). Star will confirm.Thank you it's 7 speed
Thank you, will have her checkedFairly common problem with the 7 speed is failure of the speed sensor plate (turbine). Star will confirm.
