brian bray
- May 20, 2018
- 1991 300 sl
The A/C and heat in my 1991 300 SL remains in "default" mode after replacing the A/C controller which was tested and worked. In "default mode", the heated air or the A/C air comes out ONLY from the defrost and side outlets NOT the center dash vent. Since the heater core is NOT responding to the controller, is there a way to manually set the airflow to come out the center dash vents? Thanks.
