Headlight filters for UK model to be driven in France
Discussion in 'General Mercedes-Benz Related Discussion' started by Mercator1, Oct 11, 2018.
  1. Mercator1
    Mercator1 New Member
    Oct 11, 2018
    Your Mercedes:
    GLC AMG43. Dec 2017 model
    New here so hope this post is in the right place.
    I have a Dec 2017 AMG 43 GLC. It has LED lighting and all four of the projector type (I think) headlights are on when the lights are dipped.
    We are spending next Jan through March in Southern France and need to fit anti dazzle headlight “Filters”. All the information I have unearthed states that these filters must be fitted to the dip beam light.
    So....my dilemma is “Do I fit filters to all four headlight bulbs and if not, to which ones”, remembering that all four are illuminated in dip mode.
    Any constructive thoughts or advice would be most helpful. Why is nothing ever simple
  2. Blobcat
    Blobcat Moderator
    9,417
    629
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Hello & Welcome, what does your car manual say?
    If you're talking about the stick on headlight beam deflectors then they won't be relevant to your LED's. With the bi-xenon lights there is a switch on the inside of the units. I never took my LED's over the water so didn't check the manual but it should be listed in the manual.
  3. LostKiwi
    LostKiwi Senior Member
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    If you have ILS (as I suspect you do) you need do nothing.
    There should be info in your manual.
  4. keefysher
    keefysher Senior Member
    2,368
    718
    May 4, 2007
    Hampshire
    Your Mercedes:
    W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
    Your online owners manual is open at the relevant page:
    http://moba.i.daimler.com/baix/cars..._51.shtml:ID_4937f3ef80ec3cd8351f19153b131592
    It really is simple :geek:
    I do wish a mod would make my post on online owners manuals a sticky, saves me scrolling through different ones each time :rolleyes::rolleyes::geek:
    For the hard of clicking links, the text reads:
    Setting the dipped-beam headlamps for driving on the left/right
    This function is available only in vehicles with the Intelligent Light System.
    You can use this function to switch between symmetrical and asymmetrical dipped beam more.
    [​IMG]
    Press [​IMG] on the steering wheel to open the menu list.
    [​IMG]
    Press [​IMG] or [​IMG] on the steering wheel to select the Settings menu.
    [​IMG]
    Confirm by pressing [​IMG] on the steering wheel.
    [​IMG]
    Press [​IMG] or [​IMG] to select the Lights submenu.
    [​IMG]
    Press [​IMG] to confirm.
    [​IMG]
    Press [​IMG] or [​IMG] to select the Dipped beams Setting for function.
    • You will see the selected setting, right-side traffic or left-side traffic .
    [​IMG]
    Press [​IMG] to save the setting.
    • If you change the setting, conversion does not take place until the next time the vehicle is stationary.
    If you set the dipped-beam headlamps for driving on the right/left, then motorway mode and the extended range foglamps are unavailable. These are deactivated only if the setting for driving on the left/right is set opposite to your vehicle's country version.
    A qualified specialist workshop can set the dipped-beam headlamps for driving on the left/right.
  5. thebiglad
    thebiglad Senior Member
    266
    134
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    Hi Mercator, it sounds like you've got intelligent headlights, this means you can adjust the beam pattern via the headlight settings menu. Therefore you won't need to stick anything onto the headlights themselves.
    Check your handbook for "adjusting headlight beams" or "Continental driving" or something similar.
  6. OP
    Mercator1
    Oct 11, 2018
    Your Mercedes:
    Great help...many thanks.....guess I should’ve fallen back on the old adage of.....If in doubt....read the instructions
  7. keefysher
    2,368
    718
    May 4, 2007
    Hampshire
    Your Mercedes:
    We have an acronym for that on here RTFM (Read The ****ing Manual) ;)
    Bookmark the online manual I posted and you'll find answers to questions you may have in future. A very good resource that is free :alien:
  8. LostKiwi
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    And I always thought it meant Read That Fine Manual...
    Blobcat likes this.
  9. rorywquin
    rorywquin Senior Member
    693
    240
    Dec 28, 2016
    North Yorkshire
    Your Mercedes:
    2017 SL400 with lots of fruit
    It is so easy to do, that you do not even need to RTFM......quite intuitive :)
  10. keefysher
    2,368
    718
    May 4, 2007
    Hampshire
    Your Mercedes:
    Nah.
    Lots of acronyms don't work with 'fine' ie jfdi, snafu, wtf
  11. rorywquin
    693
    240
    Dec 28, 2016
    North Yorkshire
    Your Mercedes:
    there is also a MB app that provides user manuals for smart phones......
  12. keefysher
    2,368
    718
    May 4, 2007
    Hampshire
    Your Mercedes:
    Would that be 'Guides'?
    That stopped working with the latest iOS update earlier this week :rolleyes::rolleyes:
    I do wish the kids in their darkened booths would stop playing with things that work such that they stop working, who do they think they are, microsh1te, ffs. Don't fix wot ain't broken :geek: it boils my p!55 :mad::mad:
    At least the online version as linked above hasn't been played with :):)
    I recall when doing the approval testing of the Heathrow guided vehicles at T5, there was a software upgrade that brought the airport to a standstill at peak times, just leave the f alone won't you :geek::geek:
  13. LostKiwi
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    It's next on their list now they've 'fixed' the app....
  14. Andy.M
    Andy.M Senior Member
    807
    69
    Feb 20, 2012
    Rochester Kent
    Your Mercedes:
    2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
    Shut The Fine Up :)
Share This Page
