Heater fan stopped working. 1999 SLK
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Brian23, Oct 12, 2017.
  1. Brian23
    Brian23 Senior Member
    1,134
    9
    Jan 11, 2008
    Aylesbury
    Your Mercedes:
    230TE (Gone 1st merc), E240 (Gone), 2005 E200 Estate, 1999 230SLK (wife's).
    Hi the other day I took off and unblocked the windscreen washer nozzle and now the heater fan doesn't work. Coincidence or something I have done. I have checked fuse 37 under the bonnet, which was fine and on checking all the others found that the windscreen washer nozzle fuse had blown, so I replaced it. Still no fan. Any ideas?
  2. corradoman
    corradoman Senior Member
    156
    25
    Feb 2, 2009
    This happened to my slk R171, so the newer shape, not sure if the fan is situated in the same area on yours (back of the battery) but i revealed my fan assembly and turned it by hand, the bearing is a little dry on mine, but once i had it turning again it was fine, and has been good for a few months now, may buy you some time. im sure these fans can be stripped and repaired as they are expensive new
  3. OP
    Brian23
    1,134
    9
    Jan 11, 2008
    Aylesbury
    Your Mercedes:
    I have looked and the fan is under the glove compartment. I will take it off now and see. Thank you for the reply.
  4. OP
    Brian23
    1,134
    9
    Jan 11, 2008
    Aylesbury
    Your Mercedes:
    Yes full of leaves and I think that the Brushes have seen better days lol.
  5. GlosRichCLK
    GlosRichCLK Senior Member
    241
    62
    Aug 18, 2017
    Gloucestershire
    Your Mercedes:
    2012 W212 E350 CDi Sport saloon and previously a 2001 CLK 230 K Cabriolet A208
    There are used ones on ebay, if you dont want to pay the full price for a new one.
  6. LostKiwi
    LostKiwi Senior Member
    12,103
    4,165
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Or you could just replace the brushes....
  7. OP
    Brian23
    1,134
    9
    Jan 11, 2008
    Aylesbury
    Your Mercedes:
    Well I cleaned up the brush faces and the armature and put it back together and it is better than it has ever been. I will have to get some new brushes and replace these. Winter is coming and the night is dark and full of terrors.
    LostKiwi likes this.
  8. LostKiwi
    12,103
    4,165
    Aug 25, 2006
    Your Mercedes:
    Indeed it is.....
  9. corradoman
    156
    25
    Feb 2, 2009
  10. OP
    Brian23
    1,134
    9
    Jan 11, 2008
    Aylesbury
    Your Mercedes:
    Yes an easy fix and now better than ever.
Share This Page
