CrazeUK
Make: Mercedes
Model: C220 CDI
Transmission: Auto
Fuel: Diesel
Body type: W203
Year: 2001
Hi Guys.
I fix one issue, and then something else comes up.
Anyway, I recently had an issue with the car going into limp mode.
On initial investigation i removed and cleaned the EGR valve, then finally found out it was the Mass Air Flow Sensor, which i replaced now the car is great.
Since then, i noticed my heaters do not work properly.
I am not sure if this is related but i am sure they worked while the car was in limp.
The main vents that heat the passenger zones do not blow out hot air, instead a constant stream of cold air.
The corner vents that service the windows blow out hot air, so does the windscreen heater and the foot well.
Like in the diagram below:
The air con works on all the vents correctly.
The only way i can actually heat the car up is if i roll the green arrow to closed.
Any help would be great. Having cold wrists is painful!
Model: C220 CDI
Transmission: Auto
Fuel: Diesel
Body type: W203
Year: 2001
Hi Guys.
