Arudge
- Jun 14, 2016
- Location
- Cradley Heath
- CLK200 2000 Kompressor
It will be very interesting to see what codes they come back with.
Ok so now I know what the issue is!Any news?
After being on a dyagnostic and with further investigation and having the codes the garage called Mercedes technical department with all 15 of the codes and it turns out that it is reading a positive negative! The wires are contaminated and sending shorts and mixed signals to sensors in which is causing an electrical misfire! And there was me thinking I had done something and couldn't place my finger on it, my my the frustration!! Lol.
So I am pleased to say that I can now move forward!
The issues around this contamination of the loom is that it can spread right through to the boot! YAY!
So now I have booked a well recommended sparky to come and have a look and tell me what's what, what needs replacing what dosnt and what he can or can't do!
New engine loom! No problem that's easy! But as the loom travles through the car and splits off the various components this is something that could be a problem!
But with the fella I have coming I see no reason as to why it can't be sorted!
Also on the positive side car passed mot with flying colours! Before the MOT was done I had to put on a front tyre, window wipers, and 2 number plate bulbs!
not bad for a 55reg C180!
Well looked after!
I will keep you updated as to what has happened to the loom system and where theses shorts branched to!
Sent from my SM-G935F using Tapatalk
I also had the same on my W208, I found a lot of issues and sorting those issues all helped improve things but not fully cure them. I had oil I the loom but the main culprit was a vacuum leak. The icing on the cake was the new cam chain.I had oil in the wiring loom on my C180 W203 and cleaned the connector at the after cat O2 sensor and ECU plug (not the ECU) several times with electrical contact cleaner and compressed air as it was causing fault codes but not a misfire. The cure was to fit new cam magnets and blockers to the wiring harness and clean the connectors as I've said.
The problem I had was just fault codes, the MIL and bad mpg as I said. The first manifestation was a faulty O2 heater circuit and changing the sensor obviously cleaned up that connection for a while, when the problem came back a few thousand miles later, I went off looking at the MAF etc. but when I checked the O2 connector and the ECU there was signs of oil. So fortunately changing the cam magnets, adding the blockers and cleaning several times both connectors with contact cleaner and compressed air sorted it. I bought a new Bosch O2 sensor thinking the other one would be shot but I didn't fit it as I was waiting until all the oil was at the bottom but cleaning worked and it's still in the box.I also had the same on my W208, I found a lot of issues and sorting those issues all helped improve things but not fully cure them. I had oil I the loom but the main culprit was a vacuum leak. The icing on the cake was the new cam chain.
No more misfire.
Oldspanners, Did you cure your misfire?
The hole was so big and given that there was plenty of lube 3 fingers slid in with ease!Tasty.
