DaveH
My 1989 207d van (I know its not a car but it is a Merc) has developed an electrical fault and I don't know where to start. I can't really afford to get an auto electrician to fix it so I will have a go myself. I'm reasonably competent with mechanics but electrics are a bit beyond me at the moment.
It is an intermittent fault where anything electircal (lights, wipers, indicators etc.) sometimes work OK and sometimes doesn't. Sometimes when I put the indicators on the temp and fuel gauges flicker in time with them. The headlights also cause the gauges to go beserk. Occasionally there is a short buzzing from the fuse box area. Also, the ignition will not switch off - you have to stall to stop the engine.
Obviously I am not using the van at the moment and I need to get it sorted as soon as possible so any help or advice will be greatly appreciated. I believe that the previous owner had a new alternator put on. Could the faulty be a dodgy earth somewhere?
