Ebony
Hi all,
I'm at a bit of a loss at the moment, both financially and mentally; not to mention emotionally drained.
I own a Mercedes C250 Efficiencyblue 2.2 CDI
A brief run down of problems:
1. Car starts to crank for long periods in the morning before starting, but starts.
2. One morning car will not start after long periods of cranking which drains the battery.
3. Call AA, guy jump starts the car. First suspicion is the battery, but then the guy says he thinks it's a pressure problem, not battery.
4. Take car to indie, notices small fuel leak in some pipes at the top of the engine.
5. Purchase fuel pipe from mercedes dealer and take to indie to fit
6. Crossed fingers
7. Starting problems remain
8. Indie reads fault codes, they come up P2463 (DPF), P0252 (fuel pump) and P0087 (fuel rail pressure low).
9. Did some research on the net and I suspect fuel filter.
10. Got indie to fit fuel filter I purchased from Euro parts (I went to merc first and the Euro parts one is exactly the same brand and looked exactly the same).
11. Crossed fingers
12. Starting problems remain, but car drives much smoother and no longer sluggish. I also put in Wynns extreme clean and went on a long drive.
13. Went back to indie for a DPF flush with the Normfest and a motorway drive. Lot's of smoking, thought it worked but starting problems remain.
I only have starting problems in the morning, car is fine for the rest of the day but does crank for a bit, but starts in about 2 seconds.
Any suggestions, I don't have any money left this month to take to Mercedes.
6. Crossed fingers
11. Crossed fingers
