Help - rear brakes not working
Discussion in 'Suspension, Steering & Brakes' started by daboss2000, Feb 13, 2018.
  1. daboss2000
    daboss2000 New Member
    6
    Feb 13, 2018
    Your Mercedes:
    2008 W204 C200 Kompressor 1.8 Petrol
    Hi all,
    A few weeks ago I lost brake fluid - on closer inspection the brake pipes that feed both rear brakes (between ABS pump and calipers) had corroded and leaked.
    Yesterday I had all of these pipes renewed and then power bleed by a local garage I know. They spent ages trying to bleed it and constantly topping up the reserviours. Had good flow to all except the rear drivers side where there seemed to be a lot of air.
    Anyway, front brakes all working great but rear brakes read 0% on the test machine.
    Can anyone help out - I am thinking:-
    1) Master cylinder failure - would anyone know part numner and best place to buy from?
    2) Carry on bleeding and try and engage ABS on a test drive - it might clear itself?
    3) ABS pump fault but no ABS light on.
    The car is a 2008 W204 C200 Kompressor (1.8l petrol)
    I am based in Yorkshire - does anyone know a good independent garage that can be trusted as i dont really want to start replacing things for the sake of it.
    Thanks very much - really apprecaite any support and advice
  2. LostKiwi
    LostKiwi Senior Member
    14,189
    5,508
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    In some cars you may need to cycle the ABS pump using diagnostic equipment. Smarts are known to have this issue from time to time.
  3. OP
    daboss2000
    6
    Feb 13, 2018
    Your Mercedes:
    Thankyou- does anyone know if this is the case on my particular model?
  4. mikestrivens
    mikestrivens Senior Member
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
    Yorkshire is a big place, put your postcode in here may find an indie near you: http://mercedesspecialistfinder.co.uk
  5. John Laidlaw
    John Laidlaw Senior Member
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    There are a few in Leeds like Scott’s who get decent reviews
  6. OP
    daboss2000
    6
    Feb 13, 2018
    Your Mercedes:
    Thanks that’s helpful.
    Does anyone have any technical knowledge on the issue I.e do you need to engage abs when bleeding and if so does this need to be done using Star?
  7. EmilysDad
    EmilysDad Senior Member
    6,400
    722
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    In your case, ie where the ABS block has lost fluid, then the answer is probably yes. I'm sure there will be other generic kits that do the job. I believe even the iCarsoft MBII will modulate it.
  8. OP
    daboss2000
    6
    Feb 13, 2018
    Your Mercedes:
    Thanks - does anyone else know if I have to use Star to bleed the brakes where the system has been drained or can I just bleed manually with ignition on maybe???? Can’t seem to find the answer anywhere
  9. LostKiwi
    14,189
    5,508
    Aug 25, 2006
    Your Mercedes:
    If the ABS unit has been drained of fluid then it will almost certainly require the pump cycling to drive the air out. Ignition on will make no difference at all.
    The exception to this is SBC equipped cars (which yours is not) which have a totally different set of procedures when working on brakes.
  10. OP
    daboss2000
    6
    Feb 13, 2018
    Your Mercedes:
    Thankyou - is the only way to cycle the pump via a speacialist machine (I.e STAR)? Is it worth trying to manually bleed again and see what happens first
  11. EmilysDad
    6,400
    722
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    No harm in trying, but think the pump needs cycling to bleed it properly. As above, machines other than STAR will do it.
  12. OP
    daboss2000
    6
    Feb 13, 2018
    Your Mercedes:
    Thanks for all the replies. Bled and bled again today with power bleeder and by manual method. Absolutely certain that all the air was out but then same problem again, brake pedal really spongy and rear brakes not really working (rust on rear brake discs still there after test drive). Will book it in for Star bleeding as suggested, hoping it’s not the master cylinder
Share This Page
