High Mileage CLA45, any potential hiccups to be wary of?
OnlineTeddy
CLA
Thinking of upgrading and buying a CLA45. This particular one has a fairly high mileage (70k), and I was wondering if I should be wary before buying.
Generally, you have to replace tyres every year, deal with mot and servicing ever year... that’s the usual.
But at such high mileage, anything else? potential gear box replacement required? anything? also what would the cost be for such replacements? (approximately)
Thanks in advance for your help!
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
70k might be high for the age but not for an engine these days if it has been serviced regularly. If you are worried about it going pop, get a warranty.
In another 30k it will be run in :D
Uncle Benz
West Sussex
Mainly Mercedes
Get everything hot on the test drive, then shift from drive to reverse reasonably swiftly and listen for grinding as it goes into reverse. Go from drive to reverse and back to drive a few times to be sure. Obviously if you hear grinding noises walk away.
John Laidlaw
Wirral
Land Rover Discovery 4
This is local to me
https://www.vr-eps.com/detail/28631...ate-2-0-amg-cla-45-4matic-5dr-semi-automatic/
Taffy7hfa
Oxford
70k is not high mileage :confused:
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
If these cars are looked after and serviced correctly can they go on and on even if driven hard?
John Laidlaw
Wirral
That counts for any car really, as mentioned though it’s things like getting the fluids up to temps before nailing the throttle regularly which could create future issues. So preventative maintenance rather than maintenance. But you can’t measure that sadly
www.W140.co.uk&www.r129.co
