The top item in the pic is the engine ECU, the plug to the left on this is for the engine and to the right is to the rest of the car.
The unit below it "I think" is the Traction control ECU, is it fitted?.
Hope that is of some help.
Connectors 0, 1 and 2 are on the ESP/ETS/ASR module - no.1 is the CAN wires.
Connectors 3 and 4 are engine ECU - you can again see the CAN wires in plug 4.
All the rest are on the K40 module, which is mainly involved with voltage supply and starter output. 11 is the starter relay, 12 is switched and permanent live supply, 6,7,8,9,10,13,14 and 21 are power outputs and inputs to eg switch the internal relays in the K40 (there will be 2x probably, in addition to the demountable starter relay).
Fuses are obviously there to protect the voltage outputs.
Good man Alex thanks very much, very comprehensive answer, sounds like you know what you are talking about. Useful to know what’s what, hopefully I wont need this info in the future.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
