If its 2004 or newer then it should have UHI which means you can easily change the cradle. If you have the Nokia 6150/6210/6310 type cradle with a curly cable then the best solution is to deploy a Viseeo MBU-1000 which will give you bluetooth.
If you have UHI then you can change the cradle to a fixed one for your particular phone or a bluetooth one.
