illegalhixxy
- Mar 11, 2015
- Location
- haselbury plucknett
- ml270cdi 2000
my ml doesnt have mpg so i do it by fill to fill an miles done, ol man does the same
Hello from a newbie who has been dipping in to the forum for a while and has finally joined. I have a MY2002 ML270 that I purchased in 2009 with 98,000 klm and just over 250,000 klm on it now.
The ML has been terrific for towing my 20 ft caravan around Australia and has given good economy and performance with and without the van attached.
From day one I have noticed a slight 'hunting' at idle and after reading this forum I have deleted the flaps. I left the flap motor electrically connected and will replace it with the resistor mod if it fails.
I started the flap removal job before I read the comments about it being a difficult, messy job, but once committed I have carried on over the past ten days (not full time) and have almost finished. During the job I slipped and damaged the sensor at the back of the thermostat housing. I have a plug at the end of the wiring harness and nothing to plug it into. Should I expect Error codes, limp home mode or other problems if I try to start up with the sensor not connected?
I hope it is not too ill mannered to ask a question in my first post (in my first forum too).
Thanks in advance.
Thanks oigle. This job has just exceeded my abilities a bit and the ml is booked in tomorrow for a mechanic to check and correct the sensor connections to the thermostat and the sump, (I damaged the connection at the thermostat and cannot find the wiring to connect there. The manifold itself is looking good with the flaps removed and the holes neatly plugged. With no connection to the thermostat sensor or the sump sensor, I have a lot of warning lights (and no Aircon) but engine is running well. also the engine cooling fan is running flat out, as expected.
Is the EGR delete electronic only or does a blocking plate need to be added as well? I did read the discussion thread but still not certain on that point.
Connected the resistor between the red and black wire that is connected to the swirl motor. Had the car at an auto electrician to check if the wires were ok and not maybe broken off inside the harness but it was found all in order. I then out of desperation cut the two wires and took the resistor out and left the wires open. Took the car for a spin and all in order. Came back, taped the wires so that it can not short ant left them unconnected. Done 1000km now without any problems. I can not explain how the car can now run without any problems as it should sense that the swirl motor on manufault is not connected. Not complaining as the car goes like a train with the two lose wires...Just love itHow did you connect the resistor - which wires?
What fault code do you have (P1189?)?
