Instrument backlighting not always on is this a fault?
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Dr.Strangelove, Feb 12, 2018.
  1. Dr.Strangelove
    Dr.Strangelove Member
    13
    Feb 6, 2011
    oldham
    Your Mercedes:
    s class
    My Instrument backlighting not always on is this a fault? 1st time I noticed it not lit up was driving back Mercedes service after having the auxiliary (stop start) battery replaced under warranty due to a malfunction error flashing up on the dash, it was off then lit up a mile or so into the journey home. Since then it is sometimes lit, sometimes not. It's alway ok at night so maybe it's supposed to be like that and has a sensor.
  2. jp williams
    jp williams Senior Member
    1,107
    113
    Apr 19, 2006
    Wirral & Axarqia,Spain
    Your Mercedes:
    2002 E class 2.2 cdi auto estate, Lexus GS 450h
    Have you checked to see if the lighting switch has been turned down.It is usually a thin stalk like rheostat switch which needs to be rotated clockwise to increase the brightness.
  3. OP
    Dr.Strangelove
    13
    Feb 6, 2011
    oldham
    Your Mercedes:
    s class
    Thanks. I'll look for that but I think that's not going to be the issue as I'v noticed the lighting just come on as I'm driving along without me changing anything.
  4. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,525
    1,271
    Mar 25, 2010
    Dartford
    Your Mercedes:
    The numbers/dials only light up when the headlights/sidelights are on.
  5. OP
    Dr.Strangelove
    13
    Feb 6, 2011
    oldham
    Your Mercedes:
    s class
    Car is a 64 plate E Class with automatic (always on LED) lights.
  6. alexanderfoti
    10,525
    1,271
    Mar 25, 2010
    Dartford
    Your Mercedes:
    DRL are on all the time
    headlights turn on when its dark.
    Dash back lighting only illuminates when its dark
  7. OP
    Dr.Strangelove
    13
    Feb 6, 2011
    oldham
    Your Mercedes:
    s class
    It could be that's the case. Just that I've noticed them coming on during daylight. Maybe the ambient light sensor seemed it to be dark.
  8. alexanderfoti
    10,525
    1,271
    Mar 25, 2010
    Dartford
    Your Mercedes:
    There should be a dipped beam logo on the left hand side of the instrument cluster that comes on at the same time. (underneath the temp gauge)
Share This Page
