d215yq
- Mar 28, 2008
- Age
- 39
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
Finally finished my house renovations after 9 monts so decided to give the old bus some attention for the first time after 14 months/22k miles (I know it should be serviced more than that). Before service I've done an inspection of eevrythign I can and need advice as to what to do regarding some issues that might be dangerous. Note it is very unlikely to fail an MOT over here on anything as it has passed with worst when I first got it so I want to know if any of this is properly danegrous/maybe unreliable e.g. I should think twice about the 2k miles I 'll need the car for in the next month.
1) Front wheels have play in all directions
Front wheels have play L-R T-B diagonal etc with a metal clunking from inside the wheel when jacked up. I understand this coudl be ball joint (replaced with FEBI 50k miles/2.5 yrs ago) but more liekly wheel bearings as when car is jacked up the ball joints in theory don't show play and they should last 150k miles anyway?
Can anyone give me a test to check for sure it's wheel bearings and/or instructions of how to tighten them (there is a bearing cap so imagine it can be done quite easily?). There are no clunks or humming sounds when driving to indicate warn bearings, and car has felt progressively wandery in wind etc of lately.
2) Steering wheel rod ball joints don't look uniform (see pictures).
I coudln't find any play in these though as I was on my own didn't test properly. Here are two pictures of the steering joints with (atleast the rubbers) not looking as new. Is this a problem or just quite normal for oldish joints
3) There is a greeny type substance in the tray mixed in with the old oil residue (see picture).
The coolant is that colour so maybe it's coolant although couldn't find any traces of coolant anywhere other than in the tray and level is normal so maybe it's diesel? I did do 500 miles in it yesterday some up mountains in 30 degree plus heat so maybe it just through a bit of coolant out? Is there anyway to test (I tried to use paper towel but it is just clear liquid or black residue I see
4) Jacking Points/Jack
I don't go under the car but imagine that a jacking point/jack failing near me could still be dangerous. I notice the jack has a bit of a bulge (always has - see pic) and the jacking points are rusty (see pic). They've always been like this but are they a serious problem. As I say there is no corrosion inspection on MOT here as cars don't rust very much and this rust ahs not really got worse in my 3.5 years of ownership.
5) Glowplugs (poorish cold starting)
The glowplugs 1-5 all show 0,1 on my multimeter at 200Ohm, so I guess that means 20ohm?? Glowplug 6 showed 0,8 (160Ohm?). The relay gives 11V to all of them so that is working correctly. I'm assuming that 5 are good and one is bad but don't know why that would make it poor start at 25 degrees C (like needs a press of accelerator for a second or two to get it to idle properly?). I read these were good to start with 3 glowplugs in summer temps.
6) Brakes
How do I test if discs are true - not touched brakes (other than fluid) in 70k miles of my ownership and they weren't knew when I bought it. They seem to pass the MOT test each year swhich tests the N for each wheel but would that test show if they were warped. Other than it sometimes feels a little twitchy under braking (though maybe that's just caused by issues 1/2
7) Rear Wheels
I might have felt a very slight play top to bottom in one wheel but very hard to tell. Certainly nothing side to side and nothing like as bad as the fronts so for the time being I'll ignore these
Appreciate all your comments regarding what to do with these points. Once I know what to do I'll be also doing oil, filter, air filter, fuel filter, osram nightbreakers, injector cleaner and siliconing all moving parts on top. It doesn't have to drive like new and properly true but I do use it a lot and so I don't want it to be dangerous/unreliable.
ETA in my ownership (70k miles) the only suspension parts done are RH tie rod/tighten front Right Wheel Bearing (when bought) and steering wheel damper; 2x front ball joints (50k miles ago). Tyres are all wearing completely evenly and at 50k miles still have good tread.
6) Brakes
7) Rear Wheels
