I read recently that they were mostly repackaged carb cleaner . I'm not saying that is correct though , but I work in that assumption by using carb cleaner
EGR/MAF/Brake Cleaner - its all the same; high solvent content and no oily residue
Your EGR sits between the exhaust and inlet manifolds - but i dont know where - I cant point mine out yet!!
They do get quite clogged up over time so you wont know if it needs cleaning until you take it apart: but if it aint broke - id leave it.
I have heard oven cleaner being used, it would certainly get it clean - but i wouldnt!!!
And then you get charged for a diagnostic as wellIn general MAF cleaning with a solvent is a waste of time and money.
The MAF is a hot wire sitting in the air stream and over time they build up a crusty residue on the outer surface. A solvent will rarely if ever remove it.
On some cars there is a diagnostic capability to superheat the filament to use heat expansion contraction to crack the residue off but that in itself is a fairly kill or cure cleaning technique as the increased heat can cause it to fail.
Thank youIn general MAF cleaning with a solvent is a waste of time and money.
