silestanix
- Thread Starter
- Thread starter
- #21
So yours is the post 94 pre 1/6/97 version.
Yes indeed Alistair, just a few months before the facelift... Please tell me you have WIS mate??
You could take the easy route like a 210...
They have a switch on the dash for headlight wash that just operates a pair of high pressure jets of water via a separate pump and reservoir....
It would be easy to make your own loom.
Take a feed from the headlight and use that via the switch to control the relay. This ensures it will only operate when the lights are on.
Take a switched 13v feed to the relay (you can equally use a permanent 12v if you want) and feed that to one side of the relay and the pump the other side. Needs about 3 wires and an earth.
I've probably got a spare 210 washer switch, Harry.
If I can find it, it's yours foc.
T
That would be super Andy!
No luck yet, which is not in the least surprising, given the state of my main parts stash.
I'll check stash #2 tomorrow, aka the S123.
Was also looking for a spare screen wash pump, I didn't find that either!
Thanks Harry but no hurry.
Weirdly, it failed on the drive home from the MOT! (Which was done in Leytonstone, not Salisbury).
