Keeping headlight lens clear
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
The lenses on my E500 regularly now go hazy. I can get them pretty bright with Maguirs plastex cleaner but the result doesn't last more than a week or so. I have tried a cleaner followed by a lens sealer but they still haze up again and next time I clean them I have to abrade off the sealer as well.
Any tips on keeping them clear after cleaning (apart from hiding it in the dark).
PS I use a small triangular detail sander with a cloth wrapped around the head to save on effort. Works well and doesn't spray cleaning paste everywhere.
Craiglxviii
Cambs UK
What sealer are you using? Is it UV protective..? If not, then it isn’t worth using.
Simon Barry
midlands UK
CL500 215
Mine were the same. Tried various remedies with limited success.
After final polish I now apply quality wax/sealant & renew regularly.
S500 Pete
S500 Pete
Essex
Thanks,
It came with a cleaning kit but I will check anyway
AMGeed
Poole, Dorset
S204 C180K
The latest Meguiar headlight lens cleaning kits come with a small spray container of clear lacquer sealant.
That is what keeps the lens clear for a lot longer. Any clear lacquer spray would do as well.
S500 Pete
S500 Pete
Essex
I have also looked at replacement lenses on Ebay for about £40 a pair but the amount of work involved in removing the headlight puts me off
Flyinspanner
Ruislip
After abrading/ polishing all the haze off, mask around the area well, ensure no polish left on, and give a couple of coats with a UV laquer. Should last a while. :)
mioba
Nottingham and Köln
As above. Exactly what I done on my w220.
You start with a more abrasive then finer wet dry. You see the yellow just pour off. It looks terrible but once you get the uv clear coat on it looks amazing.
S500 Pete
S500 Pete
Essex
Any recommendations for a good UV clear coat. The stuff that came with the 3M kit doesn't say it is UV and doesn't last long. It is then a pain to get off when I start rubbing down again.
Wearsafoxhat
Sunny Hampshire by the sea
E55k :S211, SL500 :R129 , V220
One of the companies I worked for recommended Vuplex, (blue tin with an orang lid) for use on my lenses.
It seems to work so far. Couple of years now. Keeps them nice and clean, no clouding over. Some sort of plastic polish.
Not sure if it provides UV protection.
S500 Pete
S500 Pete
Essex
mioba
Nottingham and Köln
I got a spray can off the bay and made sure it said uv resistant on the can.
Craiglxviii
Cambs UK
The amount of work involved replacing the lenses once they’re off is similarly unpleasant too...
S500 Pete
S500 Pete
Essex
Thanks, that's what I was reckoning on as well
