Level oil w211 on dash
firmasrl
W211 e270 1994
hi.
Maybe was posted before( if so can be removed by admin)
What is the correct level of oil shown on dashboard? On w211, 2004 e270.
In the manual is 6,5l .
Recently changed the oil( 10w40- liqui moly) and it’s showing from 7,2 l up on idle and 6.7 at around 4000rpm.
I would say the one with the engine turned off ?
abazem
Islamabad
Mercedes E270 cdi /2004/OM647
I have checked it a number of times at each oil change. It takes 6.5 litres at every oil change and when I check it next morning it reads between 6.2 - 6.3 litres pre start up.
When was the last time you changed the oil? Check if oil level sensor is properly fitted. If it is, then check the oil via manual method (you have to buy the guage though to do it). Are you topping up coolant in coolant reservoir lately?
Taffy7hfa
Oxford
What does the cars handbook say ? ;)
This. Measure oil level engine off. As the engine runs oil is thrown onto all the interior surfaces and it takes time for it to return to the sump.
firmasrl
firmasrl
W211 e270 1994
No coolant lately. Oil changed last week
abazem
Islamabad
You changed the oil last week, how much did you put in? I imagine 6.5 litres as you have posted above? I have the same car as yours and I would suggest you check the oil level manually using the guage to determine a faulty oil level sensor.
firmasrl
firmasrl
W211 e270 1994
Not by me,was changed in mercedes specialised garage.they say 6.5 . The thing is before this oil change,it showed 6.5 with engine off,and 6.2-6,4 engine on (idle)
Botus
S500/2010/500
second pic shows 7.8 ltr with no revs ( which is way overfilled ? )
onefortheroad
uk.
you'd get a warning if it was anything but ok . suprised it lets you take a reading with the engine running, my w211 wouldnt let you .
Wearsafoxhat
Sunny Hampshire by the sea
E55k :S211, SL500 :R129 , V220
My 211 lets me read the oil level when running. I can read the level from still and watch as it falls to the lower level as the engine runs.
onefortheroad
uk.
Oils meant to be measured cold and in the sump . not swirling around the engine.
John Laidlaw
Wirral
Land Rover Discovery 4
Meantime in the wacky world of Mercedes .....
onefortheroad
uk.
EmilysDad
Bury Lancs
ML350
I would have always agreed with you .... and that's what I always did. But since owning a Smart Roadster & my Merc they've always said it should be dipped be hot but after 5 mins or so to let the oil drain to the sump.
www.ckinsurance.co.uk
