Locked out
Tommyboy1
London
C200
Please help
I have an r reg c200. I've not used for months. I have a smart key but no emergency blade. I need to get into the vehicle so I can sell it. Is there a way without smashing a window
Thanks in advance
Tc
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Apply a fused 12v to the starter motor feed and earth, you should then be able to unlock with your smart key. I headlamp bulb used in series with the +V will ensure you dont get major sparks should you connect it badly
T
Tommyboy1
London
C200
Thanks for the swift reply. I can't get in to the boot or the bonnet in order to achieve this.
T
Tommyboy1
London
C200
Sorry. I should add I think the cars battery is probably dead as red alarm light is not flashing
You will just be able to apply a charger lead to the big cable on the starter from under the car, or by taking off the nearside front wheel, no other way or you pull the button up by forcing the top of the door, and using a wire, or even use the wire on the door handle
T
Tommyboy1
London
C200
Thanks a lot. Ill give that a go
Tel: 020 8863 9233
